timing and idle question?
Old Jan 19, 2006 | 11:08 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
Ok, is there anything extra that needs to be done to use a timing light one our cars? For my set up what would be a good base timing to tune from? And whats a good idle speed for my car, after i get it idling right? any feedback would be awesome
Old Jan 20, 2006 | 01:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If, by stock carb, you mean the CC-quadra, then yes, you have to unplug the EST wire that comes out of the rear of the distributor. Should be a 4-wire connector that runs along the trans tunnel. That allows you to set the base timing without the electronic advance going goofy. I would start with 0° and go from there, perhaps about 6° or so base. Timing is timing, give it what it likes.
Idle, whatever speed allows it so that it doesn't stall out when it's put into gear. I have no clue on what a good range would be for your engine. Mine doesn't idle worth a crap below 1200. Maybe 8-900 in park, about 600 in drive?
Old Jan 20, 2006 | 10:09 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The TPI cars were programmed to run at 18-22* timing at idle. But I hear that many carb'd cars run only 10-14*. Just remember that the more advance you have, the more fuel you will need to add. But it is probably wisest to give it what it runs best at.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
