Accel Ignition module
Old Jan 13, 2006 | 01:38 PM
Unholy 89's Avatar
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
Well she just laid down on me yesterday. Trailored her home and found that the three month old Accel ICM fried and died. Spoke to Accel this morning and they indicated that they had issued with the unit when used with a MSD GM Blaster coil, like my setup. Anyone else have this issue. Whats the best ICM? Delco?
Old Jan 13, 2006 | 09:10 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Accel stuff is just junk,plain and simple.
You cannot beat MSD ignition products,IMO.Their HEI module is the best performing unit I've ever seen.I once had a 427 with an HEI,stock other than an MSD module and coil,revved clean to 7300 RPM,all the convincing I need.
Old Jan 16, 2006 | 12:44 PM
TPIFormula's Avatar
Car: 94 S10 soon to be 305TBI, 01 Blazer
Engine: 4.3 TBI, 4.3 CPI "01 Blazer"
Transmission: 4L60E's
I had the same problem with a accell ICM, I also have a MSD 6al and a blaster coil. I just put a ACDelco unit in instead, dont notice any diffence between the 2 except the car runs fine now
Old Jan 16, 2006 | 01:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've had an Accel 7-pin module in my car since Nov '01. Supercoil since Aug '99 (and a Supercoil in my '84 full-size van before that). Daily driver. No issues.
I've heard many calls over the PA at the track for a "racer in need" of MSD products. Several times a season for several seasons, in fact. I've never heard of a similar call for an Accel part (although MSD, being the bigger contigency sponsor, is obviously the more used).
It's not a bad idea to stick with one manufacturer for such parts.
Old Jan 20, 2006 | 10:09 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Accel does list 2 different ICM's-1 up to '89 then another for '90.I was looking at JEGS site and they give the Distributor # that these modules fit.Possibly you have the wrong module,even the Accel site doesn't say what the difference between them is(have to call thier Tech support on that one).Or you got a bad module - it happens.Only problem I've heard about with Accel has been a quality issue with some of thier coils.I've used both Accel and MSD for years without a problem.For an example of just getting a bad unit I had a Jacob's coil go out on a '95 V8 dakota I had.Coil was still in warranty so I called they said sent it back and they sent out a new one.
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
