Which Intake Manifold Gasket???
Old Jan 20, 2006 | 01:08 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i have an Edelbrock RPM Air Gap Port exit dimensions: 1.14" x 1.95".
I'm also running Trick Flow Twisted Wedge Heads, i am not sure of the port dimensions.
My question is, which intake gasket should i use? i was using the Fel Pro 1205 before, will this work fine?
any help would be great, thanks.
Old Jan 20, 2006 | 01:12 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I believe the same size gasket you were using before will be the correct size
Old Jan 20, 2006 | 01:39 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i bought heads and intake off this guy, and he said the intake was port matched to a fel pro 1205, he included a new set. but i sold the intake and bought the air gap, but used the gaskets anyway.
Old Jan 20, 2006 | 02:38 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I'd continue using the 1205's then. Your new manifold is not matched to it so you should be fine. You could, while it's off, match port your manifold to the gaskets and maybe pick up a pony or 2 from it. Just a thought.
Bubbajones_ya
Aug 31, 2015 12:02 PM
earlpote
Aug 28, 2015 10:42 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
