MSD Blaster Coil Install Q's
Old Jan 21, 2006 | 09:02 PM
LiquidSnake's Avatar
Car: 1989 Camaro RS
Engine: L03 V8 305cid
Transmission: Borg Warner T-5
I was looking into purchasing a MSD Blaster Ignition Coil for my 89 RS but in the pictures it doesnt show it with any sort of mounting hardware...would it be possible to just drill the rivits on the factory coil and bolt the brackets to the msd coil? Because I would like to keep OEM coil location and distributor cap
Old Jan 21, 2006 | 09:09 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
I figure you have the small outside the dist. cap coil. If so then yes thats what you'll have to do, drill the rivets out. I've got one and if I remember right I believe the Blaster coil comes with the small bolts and nuts to mount it with.
Old Jan 21, 2006 | 09:19 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Yes, you drill out the rivets and then use bolts to mount the coil to the original brackets. The rivets are fairly soft and the operation should not take long to do.
I have an Accel coil and the mounting bolts were supplied.
Old Jan 22, 2006 | 10:55 AM
Car: 1989 Camaro RS
thanks thats what I figured but I just thought I'd double check
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 25, 2015 07:34 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
