fuel line question ?
Old Jan 22, 2006 | 08:29 AM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
When i got my camaro the tpi had already been switched to a carbed setup so I'm not sure how the fuel lines went stock. I'm wondering if I can use the line circled in red or if it is unusable. I want to use it for a dedicated line for nitrous.
If not what is/was that line for?
Also can I tap the main line with a y or t fitting and then hook up my inline fuel pump between the main line y fitting and the nitrous solenoid.
Old Jan 22, 2006 | 10:08 AM
Steve86TA's Avatar
Car: To many to list
Isnt that the line that goes to the charcoal can?
Old Jan 22, 2006 | 10:09 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
not sure about the fuel pump for the nitrous, but even so if that was a fuel injected carb, i wouldnt have my fuel lines clamped like that, or i'd at least use the correct fuel injection clamps.
the open line is the Vent line for the gas tank to release pressure, usually it's hooked to the black charcoal canister
Old Jan 22, 2006 | 04:09 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Not sure what you mean by "fuel injected carb". I'm not using the stock electric fuel pump with my carburetor if thats what your saying. I'm using a 7 psi mechanical pump so the clamps on the fuel line are not a big deal. I do need better clamps on though. Thanks for the info though on the vent tube. I had thought that after I had posted. I guess I'll just use a secondary fuel cell with its own fuel pump. Do I need to have the charcoal canister?
Old Jan 23, 2006 | 12:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I had to use gear clamps to solve a temporary issue . They don';t hold the fuel preasure . So I would swap them out .
Old Jan 23, 2006 | 08:17 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I've had them their since I bought the car and have never had a problem. I do plan on changing them out soon though.
Old Jan 24, 2006 | 06:58 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
lucky you mine had a nice little drip to it . I tore a fuel line takeing out the filter. SO I ahd to use the rubber line to get to work .
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
