est problem
Old Jan 21, 2006 | 05:36 PM
plathegame's Avatar
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
est problem
just installed a set of headman shortys y pipe and new cap and rotor on my t/a. car started right up ran perfect but the check engine light was on.
after about 15 mins of idling i shut the car off to sweep out my garage and i couldnt get it to start, then when it would
start for a few seconds it sounded like it was flooding out bad
i hooked up my snap on scanner and i have a est code 42. and i had a lean condition code i checked all the wiring nothing is pinched and all plugs are connected
i changed the 02 sensor because the 1 that was in the headers when i got them was used and according to my scanner it wasnt switching it was stuck on lean
i changed the module even tho i had a feeling that wasnt the problem because i have a twin turbo hood and the car was sitting outside for a while and i have only put about 60 miles on it the last 3 or 4 years and there was alot of leaves and moisture in the dist area but i still have the code for the est but the 02 sensor is switching and i dont have the o2 code anymore
im usually pretty good w/ this stuff but i have really lost interest in this car and am getting disgusted pretty easily w/ it, its probably something stupid i am overlooking
anyone have any ideas???
Old Jan 24, 2006 | 07:21 AM
CrazyHawaiian's Avatar
Car: too many ...
When I thought I had a EST problem I remember using a dwell meter to test it out. If you do a search you'll probably find my post, someone posted an awesome troubleshooting chart. From what I remember the problems with EST could be related to the module itself, the distributor itself, the ECM, or the knock sensor. I ended up with a bad distributor, and of course I replaced everything else first (EST, knock sensor, and ECM) proving that I am a fool when it comes to working on cars. What can I say the ECM tested bad but there was no difference with a good reman ECM. Dont worry your not the only one that gets disgusted with these cars.
Heres what I would do. Number one verify that the EST plug by the blower motor is connected (the one you disconnect to set timing). Number two find or make a friend with the same type of ECM and ask to try theirs as a test, unplug from their car plug into yours. After that I would use the DVM and Dwell meters to test. If all else fails replace the distributor. They break when you least expect/suspect it.
Old Jan 24, 2006 | 08:50 AM
plathegame's Avatar
Axle/Gears: 327
thanks for the reply.. i checked the est plug for the timing it looks good, no corrosion & is tight so i just printed the diag flow charts from the mitchell on demand at work.. im going to check it out on thursday on my day off.. paul
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
