TPI problem??
Old Jan 24, 2006 | 09:36 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
TPI problem??
Sometimes (usually in the morning when its cold) the engine shuts down while braking at the start of a curve. It starts up like alway, it runs like always (up until it shuts off). It doesn't always do it. Sometimes it does it just a couple miles from the house and sometimes about 10 miles from the house or maybe not at all. My foot comes off the gas, the torque convertor is locked up, the 700r4 is in OD. My foot goes on the brake, the TC unlocks, the rpm drops to the point where the transmission comes out of OD. The engine rpm begins to drop, goes back up, then drops quickly to zero. I put it in neutral and restart while going through the curve and it then stays running the rest of the way to work. Never does this more than once during the trip to work. Its a bone stock 86 IROC with the 305 TPI. It doesn't do it in the evening when the temperature is warmer. Sometimes the engine is not up to operating temp (2 miles from home) and sometimes it is (10 miles from home). Any ideas would be appreciated.
Old Jan 24, 2006 | 09:47 PM
b_the_j's Avatar
Car: 92 RS
I would start with a routine tune-up and throttle-body cleaning
Old Jan 25, 2006 | 09:49 AM
Vader's Avatar
Make sure you include a thorough cleaning and light lubrication of the IAC pintle stem while you're in there. Is sounds like it may be a sluggish IAC.
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
