mechanical oil pressure gauge
Car: '92 RS
I've searched multiple times, and cannot seem to find an answer.
Oil pressure reads 30 when cold, when warms up reads 10-15, when revved the needle "dances".
I'm assuming to diagnose the problem further, I will need a mechanical oil pressure gauge. Autozone doesnt seem to have a listing for this diagnostic tool. How much does one cost, and will it have the necessary fitting to go in the plug above the timing cover?
Also, I get a mean ticking sound coming from the valve cover/alternator area that clears up when warm. Could this be a result of clogged oil drain holes, related to my problem? I should probably invest in a few quarts of oil and valve cover gaskets, i assume. But we all know where assuming things can get us.
Eh first things first, the mechanical gauge. I seemed to have read about fabricating a gauge on here, but cannot pull up the thread.
Thanks.
Thanks.
Transmission: 4L80E/4L80E
Typically, you just buy a mechanical oil pressure gage. They come in a kit that is intended to be mounted in the passenger compartment, typically with a bracket and nylon line included, along with fitting adapters.
Car: '92 RS
five7kid, thanks for the reply.
Would this work for testing purposes?
Priced @ 14.88 at advance auto. Heck, if it looks good I might even consider mounting it somewhere.
And this would have the necessary fittings included?
Thanks.
Thanks.
That's about all it takes. I prefer the 270 degree face, because there is more space to get in the numbers from zero to 100. Makes it easier to see exactly how much pressure you have.
ambainb
Apr 25, 2016 09:21 PM
R3500
Aug 17, 2015 12:16 PM
