Please explain 3 wire alternator connector - pic attached
Old Jan 26, 2006 | 03:25 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
The attached pic is of the 3 wire connector for the alternator in my '92 Z. The previous owner had the red wire (uncovered in the pic) linked together with a cable he ran from the rear of the car for a 2nd battery for a stereo, a cable that ran to the Hot lug on the alternator, and the power for the MSD 6a. From these he had a cable that ran to the battery in the front engine compartment.
Can you please explain to me why he had this wire run together with the other wires and what that did? I can't figure it out from my service manual.
Thanks,
- Joel
Old Jan 27, 2006 | 12:45 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Brown should be switched 12 Volt and red should be hot to the battery or starter. I can not remember pink, but I would bet that it went to the battery or starter.
Old Jan 27, 2006 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The old 10SI alternators were so easy to wire. The newer CS models are a little more difficult.
http://www.ih8mud.com/tech/cs130.php
This page will explain what all the wires are for
http://www.alternatorparts.com/cs130_sbpage1.htm
Old Jan 28, 2006 | 01:10 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
is there a page like that for the 1985 TPI alternators. i have a 104 amp one and it isn't charging either. has a two prong plug with a red and brown wire. Red wire is on the back post of the alternator( 12V + hooked to the battery as well off this post) and the brown wire is connected into the factory wiring, although my guage cluster has been removed and replaced with all autometer guages. should i then insert a resistor into the switched 12V + brown wire to simulate that choke light. and if so what size resistor? 10 ohm, 100 ohm? etc
Old Jan 28, 2006 | 07:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
That's just an old 10SI or 12SI alternator
http://www.oldengine.org/unfaq/10si.htm
http://www.amphicar.net/darrellgaddy...M_10Si_Alt.htm
http://www.autorewire.com/tech/charg...10SInandd.html
Old Jan 30, 2006 | 01:04 AM
xpndbl3's Avatar
Car: 1984 Z28
thanks again stephen, that last webpage was excellent
Old Jan 30, 2006 | 06:32 AM
Engine: 6.3L - 383
Thanks for the help guys. Sounds like I should crimp a ring connector to the end and run that to the hot 12V lug on the rear of the alternator that in turn runs to the battery. I guess the previous owner had that looped in when he created this wiring mess.
Thanks!
- Joel
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
