opinions on horsepower
Old Jan 29, 2006 | 05:45 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
i would like to get some of your opinions on how much power i should be making at the wheels...i know what dd 2000(flywheel) says but i obviously don't put any merit in that program...here is what i am running:
383 1pc seal
afr 195cc heads(10.3:1 compression)
comp cams XR276HR-12 specs:
Lift 0.503(I) 0.510(EX)
Duration At 0.05 224(I) 230(EX)
thorley headers
dual flowmaster
t56 trans
3.73:1 10 bolt(not that it matters)
holley stealthram
accel dfi gen7
Old Jan 29, 2006 | 06:29 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Very similar to my setup and it made 430hp/460tq. Peak torque was at 4300 RPM and it made over 400hp from 4500-6300 RPM.
383, eagle crank and eagle 400 rods
afr 195 street heads
5 angle valve job
Had some chamber work done
Heads flowed 280 something CFM ( can't remember )
Custom ISKY cam (in the mid to high 220's )
RPM air gap intake
holley 650
1 5/8" headers
MSD billet dist.
Old Jan 29, 2006 | 07:16 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
thanks dialed...i was figuring close to 400 on both ends...i have to get it on a dyno, but it won't be until spring.....
mike
Old Jan 29, 2006 | 10:39 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
400 should not be a problem if its in good tune. That thing must rip down the 1/4 mile.
Old Jan 30, 2006 | 06:55 AM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
thanks 89...i still have to get it up to englishtown nj...not sure what it will run...i really don't see it hooking up with the stock leafs....
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
