Different wire placement on Dist. Cap
Old Feb 2, 2006 | 02:31 PM
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
I have a question. I have my wire all shifted ahead 2 spots on the Dist. Cap. Like for instance. where the #4 wire SHOULD be, thats where my #1 wire is, then it goes in order from there. This is on a Computer Controlled HEI Distributer. Will this affect anything? I dont have top end power. when motor gets around 4500-5000 range.. doesnt really rev any higher.. and power just stops!
--Steve
Old Feb 2, 2006 | 02:49 PM
Guest
Guest
Posts: n/a
Only if your base timing is off. Sometimes, on certain applications (and not just GM's) if the wires are off you cant turn the distributor enough to get the correct base timing setting. Get a timing light and check it. If its fine, dont worry about the wires.
Old Feb 2, 2006 | 10:41 PM
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
Timing is set at about 8* Advance. Seems to run best there
Old Feb 3, 2006 | 09:30 AM
Damon's Avatar
As long as they are on in the proper firing order from wherever you started with the #1 plug wire AND your timing is set correctly the distributor will never know the difference. It only knows when to fire, not which plug the voltage is going to.
It can make for a messy plug wire routing, but it won't affect the way it functions.
Old Feb 3, 2006 | 09:36 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
When the dist. was put in it was off a couple teeth. All that does is move the position of the #1 terminal on the cap. No biggie. I put mine in so that #1 is facing about 4 o'clock when looking from the front of the motor. This makes for nice plug wire routing with less wires having to cross one another.
Old Feb 3, 2006 | 10:24 AM
stitchop's Avatar
Car: 91 firebird
If your engine is stock, than that is just about right for the rev limitations, and power.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Aug 22, 2015 08:17 PM
