Serpentine setup
Old Feb 2, 2006 | 09:28 PM
mbrown's Avatar
Car: Camaro z28 1500 Truck Honda CBR900rr
Engine: 305 HO.
Transmission: 350 turbo
Serpentine setup
Hi, All
I just bought a complete serpentine setup off and 85 camaro and want to install it on my camaro. But I dont have a clue as to what goes where. Is there a good website that will have pic and digrams as to what goes where and so forth.
Thanks Guys
Old Feb 2, 2006 | 10:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I dont recall there being a true serp setup on any 85's but if you look at the tech articals you will find all the information you need.
Old Feb 2, 2006 | 10:09 PM
mbrown's Avatar
Engine: 305 HO.
thanks but where are the tech articals.. I think your right cause I didnt see any pulleys
Old Feb 3, 2006 | 01:02 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
This should give you an idea. If you search there is an article that has the routing and new belt length if you delete the smog pump. There are 2 brackets that bolt to the head and the altenator and one to the a/c compressor.
Old Feb 3, 2006 | 01:08 PM
vrtc350's Avatar
Car: 81 Corvette
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Try that.
Old Feb 3, 2006 | 08:53 PM
mbrown's Avatar
Engine: 305 HO.
Thank you this helps so much...
check my project camaro. the last 2 pics is what Im trying to put together.. I would like to have about 350 horses.
http://www.cardomain.com/ride/2245954
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
