Hi-Flow Air Filter without red oil:What happens?
Old Feb 3, 2006 | 06:53 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
Time for wash & clean my KN high flow air filter, but I don't like put the special red oil in the cleaned air filter again.
What happens if I don't use these red oil?
Please, any reply,
Thanks in advance,
Denis V.
Old Feb 3, 2006 | 07:14 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
The oil is red because it is dyed. The oil is the real reason its called an air filter. I'm sure the thing would flow really well, but your engine to prematurely fail due to the number one cause of engine failure, dirt.
Foam air filters flow more then the cotton, but with less filtration, but the foam still uses oil.
Put the oil on like K&N says.
Old Feb 3, 2006 | 07:37 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
The oil just helps the filter collect the dirt and dust
Old Feb 3, 2006 | 09:15 AM
Damon's Avatar
Yeah, the "holes" through the filter media are very large on a K&N vs. a regular paper filter. The oil makes the dust stick to a fiber when it hits it instead of just bouncing off and eventually finding it's way all the way through the media and into your engine.
Old Feb 3, 2006 | 09:33 AM
Denis.V's Avatar
Axle/Gears: No idea
O.K., thanks,
Then...What about if I use any oil for this purpose?. For example WD-40, ATF, sae 10 motor oil, diesel oil, vegetal oil, or perhaps an italian or spanish olive oil????
Denis V.
Old Feb 3, 2006 | 10:11 AM
stitchop's Avatar
Car: 91 firebird
WD-40 is not an oil, it is a solvent, it will evaporate in seconds with air flowing through it. The ATF and the diesel oil are too thick. The sae 10 will work. The vegetable oil, olive oil and Italian are for cooking.
Just get the oil for K&N!
Old Feb 3, 2006 | 10:16 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Eric B
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
