Friend is building a 350 third gen
Old Feb 4, 2006 | 09:27 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
My buddy is building up the 350 in his 89 Trans Am. He thinks it is better to do the internals first such as heads,cam,pistions,rods,ect. I think it is better to do the bolt ons first. My question is does it really matter?
Old Feb 4, 2006 | 09:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
depends if you do bolt-ons first eventually you have to unbolt them to do the internals.
Old Feb 4, 2006 | 11:23 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Do you really have to ask that question? Think about what your saying besides nitrous or SC how much hp do you think you can gain on a 245hp rated engine 40 or 50hp maybe? Heads can give you that by themselves. Did you read the TPI shootout section on this forum? A stock tpi made 410hp and 500tq with a 383 do that with just bolt ons. Your friend is right but I'm not saying his car can handle it once the engine is upgraded.
Old Feb 4, 2006 | 11:28 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I'd say do the exhaust bolt on immediatly. Stock manifolds suck to say the least.
I put bigger valve, better flowing heads on an some light porting last year and saw very little change in my VE. The exhaust was my main restriction the whole time. That is changing this year along with the intake and cam.
He may just not want to pull the motor out later (Like I'm doing now) Which is not a bad reason either.
Old Feb 5, 2006 | 08:05 AM
ede's Avatar
ede
it's much better to have a planned and matched combination than to bolt on some random parts that are a compromise as far as preformance goes then go back and try to build it from the inside out and still make use of the odd bolt ons you have.
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
gwade12
Aug 8, 2015 08:17 AM
