Much cranking needed when warm
Old Feb 5, 2006 | 10:28 PM
koll's Avatar
Car: 1991 Pontiac T/A Vert
I got a new hightorque mini starter put on my 91 TA Vert with 350 TPI. The old starter (std) used to heat up from the SLP Headers being so close. Now it keys up everytime when its cold, but once its warmed up, you gotta crank the hell out of it before she goes and when she does, for like 5 or so seconds it sounds like its running on 4 cyl. Any ideas?
Old Feb 5, 2006 | 10:34 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
when was your last tune up? might sound weird but it sounds as if your plugs are a bit fouled. bad o2 sensor?
Old Feb 6, 2006 | 10:37 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Do a fuel press leak-down test. Sounds like 1 or more injs is leaking after eng shut-down.
Old Feb 6, 2006 | 05:27 PM
koll's Avatar
Injectors are LS1 injectors with only 5k miles. All that was changed was the starter.
Also O2 sensor was changed 5 months ago.
Old Feb 6, 2006 | 05:59 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
check your fuel pressure regulator, sounds like the diaphragm is bad, pull the vacuum hose going to it and just key up the engine if it is leaking you will know, when it shoots out a stream of fuel. The other way to check it is to pull the hose right after you shut it off, if the hose is wet, it's time for a new regulator, GM has a huge problem with these on its 3800 series motors and the ls style motor in the pickkups.
Old Feb 6, 2006 | 09:52 PM
koll's Avatar
right now Im changing lifters (one is ticking like a timex) and found a few vac. lines disconnected. I think this may be the problem. Will keep you updated later this week when I finish it up.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
BBSDesigns
Aug 11, 2015 07:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
