How do you determine the correct push rod length?
Old Feb 7, 2006 | 08:08 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Old Feb 7, 2006 | 08:10 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
use a pushrod length checker, available at most decent parts stores and all speed shops.
Old Feb 7, 2006 | 08:30 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Well, I know that there is a push rod checker, but how do you perform the check, what do you look for?
Old Feb 8, 2006 | 06:41 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
You try to find the rocker arm height that will produce the least amount of travel across the valve tip as it actuates the valve.
Varying the push rod length will vary the rocker arm height.
Old Feb 8, 2006 | 07:50 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
http://www.compcams.com/Technical/Cu...g/HTML/293.asp
http://www.compcams.com/Technical/Cu...ML/306-307.asp
Old Feb 9, 2006 | 10:03 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you, thats what I needed.
redmaroz
Apr 25, 2017 07:14 AM
Reborn756
Sep 4, 2015 03:42 AM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
