bad ignition?
Old Feb 7, 2006 | 09:04 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
bad ignition?
ok since i have gotten my car home with the new motor ive had so many little problems. fouled 2 sets of plugs replaced carb and now it woulnt start. well the other day i went to start it and i knew the plugs were fouled and it started but ran rough cause of the plugs well i went though replaced all the plugs then instaled my center consle and went to start it and doesnt crank or nothin all gauges lights horn everything works but carb doesnt make that annoying clicking noise and starter doesnt click or anything. its realy starting to make me mad ive checked/replaced every friggin fuse and wire. almost acts like its not in park or nuetral im so pissed please help!!??
Old Feb 7, 2006 | 10:43 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
the main question is why are your plugs fouling? oil or gas?
gas means your idling way too rich, nearly 90% or plug foulings is from idle being way too rich, always run as lean as possible in idle. always. Check your carb after distriguishing idle is not the problem. When the motor is at higher rpm more fuel isn't a bad thing, is will put the excess into the exhaust and it'll burn at idle there isn't enough velocity to shove excess crap out of it.
oil, if the motor is new, what rings did you use, moly rings take nearly 2k miles to fully seat, you will foul plugs for the first 500 max. Cast rings seal nearly immediately.
Old Feb 8, 2006 | 09:53 PM
Screamin86's Avatar
they are moly rings and the reason for plugs fouling wer cause somehow the distributer got turned and threw timing off and we didnt know and since we kept trying to start it the plugs were flooded w/ fuel and as soon as it did kick over it fryed all 4 plugs on the pass side. it will start now its something with the neutral safety switch i accedently hit it w/ the console while instaling it and screwed the allignemnt for it. thanks for the advice and help though
pjsparts
Oct 29, 2025 06:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
