TPI 350 with supercharger combo what cam ??
Old Feb 10, 2006 | 07:15 PM
Destructive099's Avatar
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
TPI 350 with supercharger combo what cam should i use??
heres my combo
350 4 bolt main block
alum vortec heads valves good to .600 lift alves 2.02 int 1.6 exhaust
edlebrock lower intake
rest of intake up is stock
Vortec supercharge will be added running low psi around 5-6 once engine is broken in
My problem is im not all that good with cams the dur / lift ect .. now im wanting to know what came would be best to use for this combo and will it be ok to use without the supercharge while i break in the engine?
Old Feb 10, 2006 | 07:35 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
For that combo, crane cams part# 113801 is the cam you want...blower friendly 114 lsa for minimal overlap, good exhaust lift and duration that blower motors like a lot. I think that cam will be perfect for you...lots of low end torque and still makes enough vacuum for your power brakes and such.
Old Feb 10, 2006 | 07:36 PM
forgot to mention its not a roller cam, its a flat tappet.
Old Feb 10, 2006 | 07:41 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Re: TPI 350 with supercharger combo what cam should i use??
Originally posted by Destructive099
heres my combo
Im guessing he got an older block ..
could be wrong tho
Old Feb 10, 2006 | 07:47 PM
I was just throwing it out there in case its a roller block.
Old Feb 10, 2006 | 08:32 PM
Engine: 5.7 350
Axle/Gears: 3:42
The block is a roller block in that case what would be the next best cam ?
Old Feb 11, 2006 | 01:07 PM
AC's Avatar
AC
Car: Used to drive a camaro
Here's my custom Comp Cam specs (hydraulic roller:
Part# 12-419-8
Grind# NX288HR-13
Gross Lift INT/.520 EXH/.540
Duration # .050 Lift INT/236 EXH/248
LSA: 113
Engine:
4bolt 383 / -16cc Pistons
Dart Iron Eagle Heads / 215cc / 72cc
Harland Sharp 1.5 RR's
Comp Cam lifters
TPIS Intake
SLP Runners
58mm BBK TB
60# FI's
TKO600
SPEC Stg 3 clutch
Old Feb 11, 2006 | 03:54 PM
that comp grind would make a great blower cam too but i don't think he'd have enough heads to flow with that cam.
Old Feb 11, 2006 | 05:41 PM
t5350's Avatar
Car: 87 firebird
Engine: 350 tbi
Transmission: t5
if it were my decision i would go with a procharger over a vortec anyday and i would use a LT4 hot cam
Old Feb 11, 2006 | 06:17 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
so the hotcam is a good blower cam aswell? what do you think he would be hp wise with the hotcam and no blower?
Old Feb 11, 2006 | 07:46 PM
AC's Avatar
AC
Ooops..forgot to mention I run a 14lb P1SC intercooled blower.
Jake_92RS
Jan 28, 2020 10:37 PM
toronto formula
Nov 10, 2015 06:17 AM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
