Replacing a head gasket.
Old Feb 11, 2006 | 02:06 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
Hey guys, I'm about to go pick up my 1987 Camaro RS in North Haven, CT. I live in Boston and the drives about two a half hour. The Camaro's head gasket needs to be replaced as coolant is leaking into the gasoline. I had two questions.
A) Would I be able to drive the Camaro from Connecticut to Massachusetts just so I can get it back here at my home where I can then fix the head gasket?
B) How much would it cost to have an mechanic replace the head gasket?
Thanks a lot fellas
-Gerard
Old Feb 11, 2006 | 03:13 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
As far as driving the car back to Massechusettes, I don't even think that's remotely possible.
About changing the gasket...please don't take it to a mechanic to do that. A job like that, they will tear you a new one moneywise. Search around and learn the in's and out's of the engine and do it yourself. Even better, pick up a Chilton's or Hayne's manual for your car. There are step by step instructions on how to do something like that (along with tons of other jobs). It isn't that bad of a job at all (minus some clearance issues) but you don't have to take the engine out or anything. You have a great forum at your fingertips for help and advice, so I think you should utilize that to its full potential. Someone who has the correct knowledge can bang a job like this out in a couple hours.
_Clark
Old Feb 11, 2006 | 03:47 PM
hihighost's Avatar
Car: 1987 Camaro
Alrighty, thank you. Maybe I'll have it taken to my house on a flatbed or something. I do have a Haynes Manual, but I was under the impression the engine needed to be removed for the job. Thanks a lot for your advice, I'll talk to my father about doing the job ourselves and if any more problems arise, you're right, the board will be more than helpful.
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
BBSDesigns
Aug 11, 2015 07:39 PM
