Will this pan fit?
Old Feb 13, 2006 | 11:27 AM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
Will this pan fit?
I am putting a carbed 350 in the 89RS and was wondering if this pan will fit...its a pre-80 010 block from a pass. car.
I am wondering if there will be any clearance problems at the cross member.
Thanks!
Mike
Old Feb 13, 2006 | 11:46 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
I have two "010" blocks. One has a passenger side dipstick pan, and the other has a driver's side dipstick pan. They both fit my 84' Camaro the same.
Old Feb 13, 2006 | 12:21 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
Would have helped if I told you the pan I was looking at...lol
Its a replacement steel pan from summit....part number SUM-G3500X.
Its only $21.00 and seems like a good deal if it will fit and decent construction.
Thanks! Mike
Old Feb 13, 2006 | 12:52 PM
Zed'er's Avatar
Car: 84 Z28HO
You shouldn't have any problems, it's just a basic stock replacement pan. It is for driver's side dipstick though, so I'de check your block if you are unsure. Like I said, I have two 3970010 blocks, and one has the driver's side provision cast right into the block, and the other one doesn't, it has an external dipstick.
Old Feb 13, 2006 | 01:51 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
Thanks! I didnt even check to see if it is in the block or not. Will check when it gets back.
Thanks! Mike
New2Chevy
Sep 28, 2015 12:35 AM
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
matthew911
Aug 12, 2015 09:38 AM
