Valve Stem Seal Replacement
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
I am needing to replace my valve stem seals because I am getting blue smoke out the tail pipe only after the car has sat for awhile. The question is does anyone know a part number for the valve stem seals? Are they different for exhaust and intake or the same? I have found a part number on gmpartsdirect.com, but they do not state whether they are intake or exhaust and I have seen elsewhere listings for intake and exhaust. Anyhelp is appreciated.
Jeff
Jeff
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Go to your local neighborhood parts store, and ask for good quality (Fel-Pro?) umbrella type valve seals. They are the best style, easy to install, and stop any leakdown. Not too hard to change, with the right tools, just time consuming.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I just let the machine shop do mine - they had the parts - got my heads cleaned, checked, surfaced, a 3 angle valve job, intakes cut for 1.95 valves, new Viton seals installed, and my new Manley race valves installed - all for $225.
I love to do my own work, but some stuff is best left for others in my world!
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'll take the positve style over the umbrella any day. Don't have the part number on hand (try a serach?), but Fel-pro makes a factory-fitting positve for the intake side. On my old engine and for my Caprice's LG4, I used the intake set on both the int and the exh.
use the positive seals, they're differant for exhaust and intake, the parts store can find the PN. i also use the o ring seals since i'm right there. as for letting a machine shop do them for you as posted above, valve seal replacement is about as basic a repair as you can make.
NBrehm
Aug 25, 2015 11:49 PM
