timing sprocket
Old Feb 20, 2006 | 03:25 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
timing sprocket
this is a pic of the bottom sprocket but i dont know which dot to line up with to the top one
Old Feb 20, 2006 | 03:26 PM
Car: 1987 iroc z
2.
Old Feb 20, 2006 | 03:45 PM
The way those gears work, is you have multiple keyways; and you put the gear on using whichever keyway, such that the mark you want, is up.
I can tell looking at your pics, you're in the wrong keyway. Here's how you can get it right:
Turn the crank such that the keyway is pointed EXACTLY AT the center of the #1 piston. Then put the gear on the crank such that the 0 (whichever 0) is straight up. It will be super obvious which 0 looking mark is the right one.
That's all there is to it.
Old Feb 20, 2006 | 09:06 PM
Damon's Avatar
With the keyway on the gear/crank pointing up and 45* to the right (as viewed from the front of the engine) the "dot" for that keyway will point straight up. This is true for whichever keyway you have used on your lower gear.
circle = 0* advanced/retarded (i.e. straight up)
triangle = 4* advanced
rectangle = 4* retarded
Old Feb 20, 2006 | 10:14 PM
Car: 1987 iroc z
thanks guys it lined right up
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
