How bad is blow-by?
Old Feb 20, 2006 | 11:16 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
How bad is blow-by?
I'm getting some excessive blow-by. To keep from getting gassed out, I had to run the passenger side pvc below the car. The problem is most noticable on the highway when I completely let off the gas and there is engine braking (with the 3.73's). A couple seconds after I let off, a huge billow of grey smoke pours out of the back of my car, like my car is on fire. It will then stop if I apply the gas again.
I understand that the problem is a result of oil getting past the piston rings, but how much of a problem it that really? I do go through more oil now too. I just get a little worried when I run it under boost. Is this a sign that the engine could die sometime in the near future?
Old Feb 20, 2006 | 11:30 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
If it smokes when you get off it doesnt that mean the heads are the problem?
Well if it is the rings, I had a turbo Dodge that blew a lot of smoke and an pretty well for a long time, so I dont think that alone would be any major cause for concern.
Old Feb 20, 2006 | 11:41 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Well, it smokes all the time, kind of bad, but it's the worst how I decribed it above.
Also, I'm not positive if it is the rings, I was only guessing.
Old Feb 20, 2006 | 11:50 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
a wild uneducated guess: maybe its your turbo? Doesnt blow smoke when it spools up but when its idling, its blowing like crazy, who knows, im not a mechanic
Old Feb 21, 2006 | 12:42 AM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
well my 305 burns oil (go figure ) whenever i start it up or get on it, but its real bad when i get on it and past 3k rpm so i figure ive got toasted rings at 100k miles...
Old Feb 21, 2006 | 09:28 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm gonna say no on the rings and bet my money on valve guides and intake gasket. 100K on rings is nothing nowadays.
Old Feb 21, 2006 | 09:12 PM
Well i just put on that performer tbi intake last summer and i did a darn good job of cleanin up the heads so the gasket would seal up nicely so the intake cant be it. Valve guides or stem seals??? i kno the stem seals go bad in these cars but my old man had them done at sumwear around 50k, but if its valve guides thats bad isnt it? i mean couldnt that cause the valves to not seat properly with the head?
Old Feb 21, 2006 | 09:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: How bad is blow-by?
I think you're sucking past the valve stem seals, or though the guides anyways.
A turbo with a bad seal will do that as well.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
