Bouncing Speedo
Old Feb 21, 2006 | 10:02 PM
Skihorse's Avatar
Car: 1985 IROC
Engine: TPI
Bouncing Speedo
My Speedo is bouncing. Will start at correct MPH per GPS and then slide down 6-8 mph. Will bounce when turning. Where should I start?
Old Feb 22, 2006 | 08:49 AM
Start with lubing the cable.
If your car has cruise, it can also be the cruise regulator doing it, by being worn out and having friction.
Old Feb 22, 2006 | 11:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you have any luck in curing the problem, please post (I sent my speedo head in to be serviced. I lubed the cable, then replaced it and the needle still bounces a bit).
JamesC
rs_z28_vert
Sep 30, 2015 09:47 PM
IROCtometal
Sep 20, 2015 11:08 PM
TrevinE
Sep 14, 2015 03:20 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
