383" SBC clearance questions?
Old Feb 24, 2006 | 04:41 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I am in the process of building a 383" SBC. I have a 4 bolt one piece rear seal GM block (roller cam) from a truck. My question is; will the "new" Eagle SIR I beam rods #SIR5700BBLW require any grinding to allow for clearance of the cam? Or is that the reason for the these new rods use capscrews instead of the traditional bolts and nuts? I am planning on using an Eagle rotating assy kit.
Thanks, Andy
Old Feb 24, 2006 | 06:24 AM
ede's Avatar
ede
it would depend a lot on what cam you run. small base circle cam will help. you shouldn't go into it thinking or wanting to not grind parts or have clearance issues.
Old Feb 24, 2006 | 06:54 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I have the same combo. A Comp xr276hr & a Lunati 54756 cam clears in mine without grinding. Base circle on those cams are (IIRC) .875". As always, check clearances first! If a heavy plastic tie strap won't jam, while rotating the crank, between the cam & the shoulder of the rod you are good to go.
Old Feb 24, 2006 | 07:16 AM
Vader's Avatar
No trouble at the oil pan rails?
Old Feb 24, 2006 | 10:01 AM
Ricktpi's Avatar
Not on mine.
Old Feb 24, 2006 | 07:10 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanks, you guys have been a big help. Lunati it is!
Old Feb 24, 2006 | 07:25 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Be sure to mock it all up berfore final assembly to be sure
Mickeyruder
Sep 2, 2015 02:45 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
