Is it possible for an intake gasket to cause this?
Old Feb 25, 2006 | 06:03 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
The car sat for 7 months after a collision. It was not driven afterwards. The radiator was busted. I replaced everything and got it road ready. It's dual exhaust and it's smoking out of the drivers side. White smoke. I would normally say head gasket but I did a compression test last summer not too long before the accident and it checked out fine.
Last summer the drivers side intake gasket was leaking around the bolt holes. Two at the front of the intake right over a exhaust valve. I put some teflon sealant on them and torqued them down. I think the gasket was shot but did it anyhow in hopes it would hold. It was fine until the accident. My guess is this gasket failed and is leaking coolant down there and going out through the exhaust.
Do you think I am correct? It runs fine and is actually overcooling since I put in a bigger radiator. It has a miss at idle like a vacuum leak. I've got my fingers crossed this is what it is. I can do a head gasket but I'd prefer not if I can help it.
A few people told me to get it a little warmer and drive it a little more. Since it was sitting it may have some water to burn off inside that exhaust . If that was the case, the right side would be smoking too.
Old Feb 25, 2006 | 06:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yes it could very well be leaking coolant into the heads if the intake gasket is leaking.
Also could be caused by cracked head/block, headgasket or some somrt of alien from mars.
Pull the intake and take a peek around for coolant and replace the gasket and see what you get.
Old Feb 25, 2006 | 06:53 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Thanks I am going to give it shot early tomorrow morning. My ride to work depends on it monday. All vehicles are down.
Old Feb 26, 2006 | 10:15 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Headgasket on that side. Rear cylinder blew the wire ring. No damage to the head. The oil milked up fast. It was fine before I started it the other day. I replaced both sides of the headgaskets anyhow.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
