confusing non thirdgen starter problem!!!please help!!!!
Old Feb 26, 2006 | 11:06 AM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
ok so i installed a high torque mini starter on my girlfriends 70 nova ss. the car has a 350 4 speed w/ 11:1 compression and a mild cam...the original starter had only 1/4 of its impellor touching the fly wheel, and had no shims on it...so we bought a new high torque starter for it..the difference between the 2 are that the original(mini starter) was like a standard starter where the impeller is covered and has opening for flywheel contact...but the new one did ot have this hood. the impeller already sticking out..so now the problem...after installing the new starter w/o shims, when you go to turn it over, it is not making contact with the flywheel at all...iot is just free spinning.....its lined up int he correct holes and cant really be adjusted(except to change positon of the motor and solinoid)..also the flywheel appears to be fine and have no damage to the teeth..so i am confused, there were 2 shims that came with the starter, but i figured buy installing them it would just make the impeller farther away from the flywheel....please help if have any info....i'm stuck
fustrated and confused
dave
Old Feb 26, 2006 | 09:51 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
It sounds like the solinoid is not working, it should push the gear out to engage the flywheel. I am not sure why there is an impeller in the starter, the impeller should be in the water pump.
Old Feb 27, 2006 | 12:41 AM
ok, problem solved, just moved the starter to other mounting holes that were drilled, and machined a little aluminum off the bracket to clear the headers,,,,thanx for the help
dave
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
