305 heads
Old Feb 26, 2006 | 01:58 PM
littlezac's Avatar
Car: 84 Firebird
305 heads
Would the Dart (DRT-10110010F) heads work very well on a 305.
Old Feb 26, 2006 | 03:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The only problem I could see with using those heads on a 305, is the valve size is pretty big considering the small bore of the 305 block. Those heads use 2.02/1.60 valves, which I don't even know will clear the stock 305 bore? Even if they do, an intake valve that big would cause some really bad shrouding problems.
A set of heads thats basically designed with the 305 in mind though, are the 175cc TrickFlow aluminum heads. They use 1.94/1.5 valves, 56cc chambers, and 175cc intake ports. They would probably work better on a 305 than those Darts would, because of the smaller valve size. IIRC, the TFS 175cc heads also outflow the 180cc iron Dart heads anyway, and cost roughly the same.
Old Feb 26, 2006 | 03:25 PM
Air_Adam's Avatar
(TFS-30300005)
$1005.95 at Summit, a little bit more for the sets with better valve springs. Those are for centerbolt valve covers.
(TFS-30300001)
$969.95 at Summit for the same heads for perimiter bolt valve covers.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
