what's better?
Old Feb 26, 2006 | 05:30 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
what's better?
i have a tbi, thought maybe about going to carb. easier for power adder i believe... what do you all think is better? or should i go with a tpi set up?
Old Feb 26, 2006 | 05:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what power adder?
yea, carbs are generally the best, easiest to tune, cheapest, etc.
Old Feb 26, 2006 | 05:53 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Re: what's better?
You will have more power potential with a carb.
Old Feb 26, 2006 | 05:56 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Daily driver, EFI. Racecar/weekend cruiser, carb. Unless you're going to do something worth while like a F.A.S.T. setup or XFI with a good intake.
Old Feb 26, 2006 | 05:58 PM
Car: ws6
Engine: ls1
Transmission: m6
TPI can make a good street car. For the strip carbed is usually the way to go.
Old Feb 26, 2006 | 08:20 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Originally posted by Sonix
what power adder?
superchargers...
Old Feb 27, 2006 | 09:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
ok, then you have to worry about it being blow through, or draw through, neither of which I know much about. (go to the power adder section).
How do you convert a carb to be a blow through? can a q-jet be? hmm....
