valve lash?
Old Feb 26, 2006 | 10:22 PM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
valve lash?
ok i get how to adjust it but how do you know what to adjust it to? do i need to check mine when i assemble my heads? im using roller tip rockers
Old Feb 26, 2006 | 10:34 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
as long as it's the factory cam then just tighten the rocker nut until the pushrod JUST stops spinning freely and tighten 3/4 turn more. If it's an aftermarket cam then contact the manufacturer for how tight their lashes should be. For instance my comp cam needed 1/2 turn past zero lash, or when the pushrod stops spinning freely while the piston is at TDC compression.
Old Feb 26, 2006 | 11:30 PM
muteboy49's Avatar
Car: 84 Camaro
thanks man
Old Feb 27, 2006 | 11:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.compcams.com/Technical/In.../Files/145.pdf
Page 2.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
