Carb conversoin ?'s
Old Feb 27, 2006 | 11:34 PM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Carb conversoin ?'s
before i reallly think about this, i could get a performer rpm intake for my car plus a 600-650 cfm carb for free(or may buy 750 for $270), but i am wondering what i would need to do to make this work? i don't know what to do to the computer, what igniton box to get, new fuel pump or not..ect....i saw a few areas about getting the different distributer...my mods are
zzx cam w/ 1.6 rr
dart iron eagle heads..200cc/ 64cc
midwest 2800-3200 stall and transgo shift kit (700r4)
3.42/3.45 australian borgwarner(cant remember gear ratio 1 of them tho)
TES headers custom y-pipe.
150-200 wet shot nitrous
i am thinking about his becaus i was goin to buy a stealthram, 32# injectors,new pump...ect but am thinking about going carbd cuz it'll be free. and it will save me close to 1k if not more....
any help would be great..oh and i did search and did not find anything abnout the computer and other areas
dave
Old Feb 28, 2006 | 02:01 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
not a hard swap all info is on here. basically you need manifold,carb,hei distributor, 3 port fuel pressure regulator and tranny tvss cable adapter. then computer goes by by. a little wireing for fuel pump, fans and stuff.
Old Feb 28, 2006 | 04:55 PM
yea i wasn't sure if i would be able to just leave the computer in and not have the chip burnt or anything and let it still read the sensors and stuff, i still paln to keep my digital dash, but am getting rid of ac/smog/and egr...the intake is a performer rpm with a 750 holley carb. do you know where i can get the cable adapter and the pressure regualotor (part numbers too???))
thanx for all the help
dave
Old Feb 28, 2006 | 06:56 PM
SPIKE's Avatar
Car: 86 CAMARO
sorry dont have part numbers. tranny board had a post with one from a truck site that was hi tech. mallory makes a good 3 port regulator. try carb board search its everywhere or try jegs.com or summit they have them both.
Old Feb 28, 2006 | 10:10 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
say good-bye to your lock-up too when you ditch the computer.
Old Feb 28, 2006 | 10:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Lockup can be achieved by an aftermarket kit or a simple toggle switch, thats going to be the least of his worries on this swap!
Old Feb 28, 2006 | 10:17 PM
well i am not set pon the swap. still waving the pros and cons...its about 400-500 doallar difference between the 2, so im still stuck
dave
Old Feb 28, 2006 | 10:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
oh forgot the easiest way to get lockup, find a canadian car. Almost all of the carbed canadian cars didnt have a computer and used a small vac switch to operate the lockup. Probably get one free at the junkyard...
Old Feb 28, 2006 | 11:52 PM
i think i may just go HSR instead, mostly because i cant tune a carb for crap, and am totaly inexsperienced with them.
dave
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
