gas gauge going crazy
Old Mar 1, 2006 | 01:28 AM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
here's the problem, when i bought the car the gas gauge didn't work, sometimes it said there was gas, sometimes it was completely empty, and then it would go right to full. what seems to be my problem? did the float come loose or did my ground come off or is it a fuse? i thought it woule be nice to know just how much gas i have.
thanks,
ps. its in my 1991 rs convertible 305
Old Mar 1, 2006 | 01:44 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
had the EXACT same problem with my Pontiac 6000. TUrned out to be the gauge itself!
Old Mar 1, 2006 | 02:28 AM
jer4251's Avatar
Car: They all sit.
well i'll go ahead and try that first then to see if it works. beats removing the gas tank. can i just pick up a new gauge at autozone or do i gotta go to the dealership? i guess i'll find out in the morning, thanks for the help, i'll update tomorrow
Old Mar 1, 2006 | 02:31 AM
1989karr's Avatar
Engine: 3.4 / 5.0
I'm not sure how it is for the third gen, but for the 6000, I need to get a replacement (discontinued though) or get one of those aftermarket ones that reads 0 - 99 (digital). I'm told that those are thwe only ones that work with the GM sending unit.
Oh, might be the actual sending unit itself too
Old Mar 1, 2006 | 08:37 AM
V6camaroman's Avatar
well ive never actually seen the indash guage go bad myself. first with the car running get under it and with a hammer lightly tap on the bottom of the tank, see it it starts working correctly.... if it doesnt im gonna have to put money on your sending unit being bad. although i thought that once and when i got the tank out i found the wire going to the sending unit had fell off of it. so anyways i still had to pull the tank.
Old Mar 1, 2006 | 12:31 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Yes...I know it s extremely rare for the gauge itself to go bad.....just my luck that my gauge went bad!
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BurlyChev
Aug 16, 2015 09:08 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
