New motor almost ready!!!!
Old Feb 27, 2006 | 09:48 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well looks like I will have my motor finished in about a week.
Im having the heads worked and put together, then its a matter of putting them on.
Here is my new combo.
L98 bottom end.
Comp xr282hr-12
10.3 to 1 compression
AFR 190's ported with 27* valve angle
Cloyes double row timing chain.
Crane Gold 1.5 rr's
Edelbrock RPM airgap
MSD Pro Billit dist
MSD 6a
MSD 8.5 mm wires
Hedman 1 5/8 LT headers
2 1/2 in dual exhaust with dynomax bullits
Trans:
TH350 with Transgo rebuild kit
10" jegs 2700-3000 converter
Rear:
stock with Richmond 3.73's
26" tall M/T tires.
Carb:
I have a Speed Demon 750 vs and a modified Holley 3310 750vs (Maybe swap out at T&T and see which works best)
I have the weight down on the car. I still need to check to know for sure.
What do you guys think. Should have some go TQ/HP.
Old Feb 27, 2006 | 05:24 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Sounds
Any pics?
Old Feb 28, 2006 | 07:48 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have to get a new battery for my camera.
Old Feb 28, 2006 | 10:16 AM
vrtc350's Avatar
Car: 81 Corvette
Bummer!
Hopefully you'll be able to get it installed quickly. Mine has been finished on the stand for 4 months.
Old Feb 28, 2006 | 10:21 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I still have to build my TH350 also. Our local track opens march 11th, but it will probably be april before I get the camaro out.
I could get the motor/trans in over a weekend, but then there will be bugs to work out.
Old Feb 28, 2006 | 02:57 PM
vrtc350's Avatar
Car: 81 Corvette
The biggest thing that I need is the rest of my exhaust components and nickel dime stuff. I just need to get off of my *** and get the engine dropped in. I have pretty much sorted out what wires I knew weren't need. I still have a bowl of spaghetti in the engine bay.
I guess weather has been kinda a factor too. As you know around here the weather can't make up it's mind.
Old Mar 1, 2006 | 07:31 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Luckly im indoors. I just fire up the heater and im good to go.
On the wires, I started cutting one at a time untill I got rid of the unneeded wiring. It takes time, but is worth it.
I think I will install new motor mounts while the motor is out. Might even do some painting on the crossmember.
Old Mar 1, 2006 | 11:31 AM
vrtc350's Avatar
Car: 81 Corvette
Yeah I need to rustolium my engine bay. My car is a rust bucket. I plan to eventually get another body. That may be a factor in my lack of motivation as well.
Old Mar 1, 2006 | 01:00 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Luckly mines not bad rusty. Just needs some cleaning up and a fresh coat of paint. Maybe go with a dark grey on the suspension.
The firewall and inner fenders are semi-gloss black.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
