Re-using hydraulic roller lifters
Old Mar 2, 2006 | 03:32 PM
shawntmartin's Avatar
Engine: ZZ4
Transmission: TH-350
Axle/Gears: 3:73
Mine still look good so I was wondering if I could re-use these with a new hydraulic roller cam?
Old Mar 2, 2006 | 03:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I did.
Most do. If there is scoring of the wheel, or the wheel doesn't turn smoothly, replace. Otherwise, should be fine for use.
(I had mine soaking in oil for 4 years before I actually used them. You probably don't need to do that, though. . .)
Old Mar 2, 2006 | 03:46 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I reused all 15 of mine, but one had a crack from the bottom to the roller part so I bought a new one.
Old Mar 2, 2006 | 05:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
All 15?
Old Mar 2, 2006 | 05:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
The 15 I had and I bought a new one making 16
Old Mar 2, 2006 | 06:44 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Used the same 16 with 3 different cams & 2 different blocks.
Old Mar 2, 2006 | 09:14 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Like the above said you are probably OK to reuse the rollers if they were working properly. However if you are installing stronger valve springs than there is a posibility of a weak roller showing up that you would not notice with the factory springs.
Old Mar 2, 2006 | 09:21 PM
ljnowell's Avatar
A weak one? At worst you could take apart just about any hydro lifter and steal the plunger and check ball springs out of it.
Old Mar 2, 2006 | 09:32 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Rick, how many miles have you put on them? Is there any sort of mileage limitation to these little buggers?
Old Mar 2, 2006 | 10:06 PM
Car: 1989 GTA
Engine: 369 TPI
ljnowell, true as to what you say. But at what point do you find out? Is he going to take the rollers all apart and inspect and clean them? I'm just trying to bring up things to think about.
Old Mar 3, 2006 | 06:25 AM
Ricktpi's Avatar
Over the past 6 years, 15,000 miles.
Old Mar 3, 2006 | 10:08 AM
Engine: ZZ4
Axle/Gears: 3:73
Hyd. roller lifters
Anyone know of a hyd. roller lifter that will handle 340-350 lbs open pressure but is still easy on the wallet? Everything I've seen is $250 and more.
Old Mar 3, 2006 | 10:57 AM
five7kid's Avatar
That's a heap of spring for a hydraulic cam. That suggests a lot of duration and lift. The first thing you'd better consider is whether the stock retainer system can handle it. The only way to get above a certain lift on the lobe is to cut the base circle smaller, which drops the lifter farther down into the hole - which can disengage the dogbone anti-rotation device. Get that clear before you proceed.
If you aren't using that much lift, then the question is, "Why so much spring pressure?" If you don't really need them, go with lesser springs.
Another thing to consider is a "rev kit", which relieves the valve springs of the duty of keeping the lifters on the cam lobes. Splits the duty, if you will, allowing the valve spring to work on just the valve, rocker, and pushrod, while this other spring works directly on the body of the lifter (and therefore doesn't tax the hydraulic portion of the lifter). A much better approach, in my opinion, as it allows much higher RPMs without the strain on the rocker/pushrod of high spring pressures, and takes the hydraulic lash adustment out of the lifter-return picture. Probably costs less than new hydraulic rollers, too.
But, if the lift is your limiting factor, the rev kit cost benefits aren't going to be there.
Old Mar 4, 2006 | 10:25 AM
Car: 1989 GTA
Engine: 369 TPI
With my new cam I'm going with the GM factory rollers 2nd design. I'm also using the Comp Cams beehive valve springs 26918. Seat pressure is 130 pounds and open pressure is 318 pounds. You don't need the high pound springs with a beehive style spring.
Old Mar 4, 2006 | 10:37 AM
ljnowell's Avatar
You are right. Alot of people wont dissasemble and clean them. It takes only a few minutes per lifter, though, and it doesnt cost a thing.
Old Mar 4, 2006 | 11:44 AM
Engine: ZZ4
Axle/Gears: 3:73
Open pressure
Alright. Someone has to give me the correct info. My cam is a 228/232 dur. with .529 lift. I have so many conflicting opinions about spring pressures with a hydraulic roller cams that it starting to annoy me. I just want to do buy the right parts but I can't seem to find any matching info. My cam compnay says 130# seat and anywhere from 280-320# open @ .530 lift. I have a few engine builders on another site saying 300# open isn't enough to keep the lifter on the cam. I have Crane cams telling me 120# seat and 340-350#s open pressure is ideal for rollers. I have my cam company telling me 120# seat doesn't cut it.
Whats the correct info??!!?
The reason I asked about the 340-350# open pressure is because that is a spring option (125#seat/347#open@.529) that comes on the heads that I'm looking at. The next weakest spring option is 120#seat and 319@ open but I assumed the 120# seat was too weak. HEEEEELLLLPPPP!!!
Old Oct 29, 2006 | 01:13 AM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Did you ever get an answer to this from anyone at all? I'm curious to know because I'm wondering if the springs I've got in my set up are good enough or not.
Old Oct 30, 2006 | 07:57 AM
Engine: ZZ4
Axle/Gears: 3:73
I had a shop shim them to 130# AND 330#S OPEN. Works great.
Old Oct 30, 2006 | 10:00 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
89 GTA, I have those same springs, what are you using as a spring cup, there an off size and nobody seems to make ones that will fit?, I don't want to gall up my TF Al. heads when I get the thing togeather (I'm in the prosess of building my engine), also I have comps P/N 853-16 retro-fit Hyd. roller lifters, and nobody seems to make a rev kit for them, I got a used one on E-bay, but the buttons don't fit in the lifters
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
