oil weight for road racing?
Old Mar 2, 2006 | 11:31 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
I've got a 383 with a high volume oil pump and an oil cooler. The rod and main bearing clearances are both ".0025. I'm looking for suggestions on which oil to break in with, and what to run after. I'm leaning toward a good 10-40 or 20-50 for break in, and probably mobil1 10-30 after a few hundred miles.
Anyone know a good source for oil recommendations depending on bearing clearance? I searched and searched...
Old Mar 3, 2006 | 12:31 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd use 30 weight for break-in with GM engine oil supplment can added as well for the zinc content. then 10W30 mobil one after break-in and the rings have seated.
customblackbird
Aug 15, 2021 10:16 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
