how about a mechanical pump?
Old Mar 1, 2006 | 08:58 PM
bigbird89's Avatar
Car: 86 Firebird
I am having trouble with my fuel pump - my relay won't click and the pump doesn't come on. As much trouble as people have with these, has anyone installed a mechanical pump on a TBI engine? It seems like it would theoretically be possible.
Old Mar 1, 2006 | 09:12 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Theroretically , yes practically, no. It would be more work and cost more to convert to a mech pump than it would be to replace the elec pump. If the relay is not "clicking" then its probabily not the pump. Check the relay for power in and out using a volt meter. if no power coming to the switch side or power side check the fuel pump fuse. if power is there the relay likely is bad. Not that hard to replace.
Old Mar 2, 2006 | 12:59 PM
bigbird89's Avatar
Car: 86 Firebird
I've already replace the relay, and it's gettin power to the switch, but I'm not sure if i'm testing it correctly. I have a light tester, and I stuck it in the varios receptores in the plug. One of them seemed to have constant power, but the others had nothing, even with the key on, so I'm still hunting for info. Thanks for your reply.
Old Mar 3, 2006 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: how about a mechanical pump?
I've done it, and it does work. It was a temporary set up until I installed the electric pump. Used a stock AC pump (from like '69) that pushed 8-9 psi and no vent return line present. With the lower pressure I did have to increase the BPC in the PROM to compensate (bumped from 140 to 181).
I did consider using a race mech pump that provides 14 psi. That would have worked better and wouldn't need the PROM modified. Just that I had the electric and cheapness reigns.
RBob.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
