Cams....
Old Mar 3, 2006 | 02:25 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
Cams....
I am curious as to the drawbacks and whatnot of the diffrent types of cams. Solid/Mechanical, Hydraulic, Roller and Flat. What kind of precautions or high maintanance has to be executed?
Old Mar 3, 2006 | 08:22 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Anythnig in a solid lifet , will require a bit of attention . You need to keep setting lash . I am not sur eof the intervals but , it's just more maintenance .
Hydraulic ... need to be set once then forget it . You can make nice hp with hydraulic cams , but top performaers liek the solid units .
Roller is superior to flat tappit . For obvious reasons ( less friction ) . Also you can have a more agressive ramp rate with a roller setup .
..Thers is ALOT mroe on this but I just thought I'd toss up a few tidbits of infor for you to maybe do a key word search on it.
also try that website called how it works .com
jethawk
Theoretical and Street Racing
Sep 27, 2006 10:20 PM
ResurrectingZ
Jun 15, 2006 12:50 PM
roachjuice
Jun 14, 2006 11:07 PM
FlamedROC
Feb 11, 2003 11:16 AM
