cam install finally...
Old Jun 12, 2006 | 12:06 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
well i have all the parts i need and i am doing the swap..... wednsday..... how long do ya think it will take and should i be careful about anything... any sugestions or experiences with tpi cams.... would be helpful... thanks...
Old Jun 12, 2006 | 12:58 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You might want to replace the timing gear & chain while you're there. Water pump too? New Plugs/Wires/Dist. Cap/Rotor? AFPR?
Bag & tag all the parts, lifters (new?), rockers, etc. Take digital photos before you start and during disassembly.
Bring the number one cylinder to TDC before you take it apart. Mark the Dizzy position with a felt marker.
Losen the front several bolts on the oil pan and cut the metal tabs on the timing chain cover to help get the cover back in place. Mine was a bitch, and leaked when I was done.....
Buy all of your Gaskets, Black RTV, Teflon Thread Sealant, Paint, Solvents, WD-40, Motor Oil & Filter, blah, blah, blah.... Clean the parts well before you seal and paint.
Clean all of the bolt threads with a wire wheel chucked on a drill, USE SAFETY GLASSES!
Take a good look at where the timing gear mark is before you take it apart. Photo!
It's a pretty big job, especially if you've never done it before. Take your time and it will turn out well.
What cam/lifters did you buy? Non-Roller right?
Old Jun 12, 2006 | 11:58 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
Camshaft Specification Table
Part Number 12-262-4
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS XE262H-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.464 0.47
Duration At 0.006 Tappet Lift 262 270
Valve Timing At 0.006
Open Close
Intake 21 61
Exhaust 73 17
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.309 0.313
Lobe Separation 114
Recommended Valve Springs 983-KIT
new stock lifters and stiffer springs... new everything...
1.6 roller tip rockers chrome moly pushrods double roller timing set
water pump is about a year old and the cap rotor wires and plugs not even 4 months old
Old Jun 13, 2006 | 12:31 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Nice!
Be careful when you remove/install the cams. You have to lift up on it as you pull/push to keep from bumping the bearing surfaces on the far end of the cam. You should use cam lube on the lobes, and plenty of clean oil on everything that moves.
Be easy on the engine for the first 200 miles at least. It'll be tough, but keep your foot out of it. I'd change the oil at 1000 miles or so. I'd bet that you'll need more than stock fuel delivery with that cam.
Stock fuel injectors? AFPR?
What heads and exhaust will you have?
Old Jun 13, 2006 | 12:02 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
stock injectors and bbk afpr getting it tuned stock heads might port them later down the road.... and i'm getting a magnaflow exhaust...
what kind of numbers ya think i will put down??? and i might get a stall....
Last edited by roachjuice; Jun 13, 2006 at 12:03 PM. Reason: Automerged Doublepost
Old Jun 13, 2006 | 01:06 PM
mnorton's Avatar
Engine: 305 LB9 TPI
With a good exhaust, 1.6 Rockers, un-ported stock heads, 19 lb. fuel injectors at ~46 psi, and a tuned chip, I suspect that you will end up with about 265 HP at the flywheel. That cam would perform better with more available air flow and more fuel. The heads and injectors will be holding you back some.
You'll actually have more valve lift than the heads can use... Maybe more lift than the stock heads can handle... I hear that .490 is pushing it, and you'll have more than that with the 1.6 Rockers.
Old Jun 14, 2006 | 11:07 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
well the cam is in and i am too tired to mess with the rest...... all it needs now in the upper plenum tightned an oil change coolant and cooling fan connected.... took me 10 hours to get everything in there.... that sh it sucks.... can't wait to run the car tomorrow... will have video of this....
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
