Vacuum Questions - Throttle Body and Plenum
Old Jun 12, 2006 | 07:27 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Ok so I'm swapping to TPI (speed density) from TBI and have some questions.....On the Driver's side rear of plenum there is a vacuum port, where does it go?
On the throttle body there a 2 ports on passenger side and one small port on bottom. I have the EGR solenoid on the bottom of the throttle body. I have the Charcoal Canister on the smaller of the two but hwat goes on the top port?
Also, I have oil breathers on both valve covers, do I need a PCV sinse I'm setup for speed density?
Old Jun 12, 2006 | 07:39 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
On the Driver's side rear of plenum, that vacuum port is for your brake booster, the top port on your tb is for your pass. side pcv valve.
Old Jun 12, 2006 | 08:31 PM
techno101's Avatar
Car: 1989 Camaro RS
I have the brake booster on the lower intake on the driver's side between the runners. Is this incorrect or what?
Old Jun 13, 2006 | 02:33 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
on a TPI the brake booster attaches to the barbed fitting on the lower left side at the back of the upper plenum.
Old Jun 13, 2006 | 03:30 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You have your booster hooked to the PCV port. One of the two on the throttlebody goes to the valve cover, the other one was something for the charcoal canister. I can't remember which one is which. The one on the bottom of the TB goes to EGR solenoid and valve.
Old Jun 15, 2006 | 12:08 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
link to diagram
Here's a link to the autozone's website with diagrams for the vacuum connections.
</title></head>");
newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>");
newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("yes") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("yes") + "\");'></FORM></td>");
newWindow.document.writeln("<td><form><input type='button' value='Close' onClick='javascript:window.close()'/></form></td></tr></table></div>");
newWindow.document.writeln("<br/>");
newWindow.document.writeln("<div align='center'><font face='Veranda, Arial, Helvetica, sans-serif' size='-2'>Copyright &copy; 2002 Delmar, All Rights Reserved.</font></div></body>");
newWindow.document.writeln("</html>");
newWindow.focus();
newWindow.document.close();
newWindow.print();
function pop_norm(pc, tpe, sze)
newWindow = open("","","directories=no,menubar=yes,toolbar=no,location=no,scrollbars=yes,resizable=yes,height=400,width=700,left=50,ScreenX=50,top=120,screenY=120");
newWindow.document.writeln("<html><head><title></title></head>");
newWindow.document.writeln("<body><div align='center'><img " + getWidth("no") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>");
newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("no") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("no") + "\");'></FORM></td>");
newWindow.focus();
function getValueToPass(valPassed)
if(valPassed == "yes")
return "no";
else
return "yes";
function choose(formAction)
with (formAction)
ref=options[selectedIndex].value;
document.location=ref;
function getButtonValue(val)
if(val == "yes")
return "Enlarge Image";
else
return "Print Image";
function getWidth(prnt)
if(prnt == "yes")
return "width='650' ";
else
if(prnt == "no")
return "";
</script>
<title>AutoZone.com | Repair Info | GM Firebird 1982-1992 Repair Guide | Emission Controls
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
