How to make a valve cover baffle?
Old Mar 4, 2006 | 02:42 PM
92heritageRS's Avatar
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
Pictures would be great.
Old Mar 4, 2006 | 04:04 PM
Get a set of stock ones, turn them upside down, and look at what's in there.
What you see, is how you build a baffle.
Old Mar 4, 2006 | 06:25 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Could be done a hundred different ways.
Put the hole in the valve cover where you want it. Then measure how much clearance you have between the valve cover and the rocker arm. Cut a piece of sheet metal or aluminum narrow enough to fit inside the valve cover and 3-6" long. Make a couple standoffs to hold the plate 1/4" or so away from the valve cover. Tack weld it in place centered under the hole in the cover.
Use your imagination. All you have to do is make a barrier between the oil and the hole in the cover.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
