aluminum vortec heads
Old Mar 5, 2006 | 05:10 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
do these heads off of ebay look like they would be worth it
http://cgi.ebay.com/ebaymotors/ALUMI...QQcmdZViewItem
dont know alot about heads and such, but these look like they sould be fairly good on a mild/decent 350 build (400hp)
also app. what are valves, studs, and guide plates gonna run to complete these?
Old Mar 5, 2006 | 07:51 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Add valves, seals, springs, retainers, studs and guide plates and your price is right there with all the other well known heads. I would do some more # crunching. What is your plan for a combination? It all has to match.
Old Mar 5, 2006 | 04:21 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
355
flat top forged pistons
probably forged crank
stay with the t-5 till it blows then go with a built 700
not positive on intake yet, maybe edlebrock rpm or weilend stealth
then whatever cam will work for the setup
mainly a driver car, with a few track runs now and then
Old Mar 5, 2006 | 04:56 PM
Rob Wade's Avatar
Some of the carb guys might have a better opinion on cams but the rpm air gap is suppose to work well. I would stay around the 180-190 range for runner volume. Should gain you some nice low/midrange power and pull easily to 6000 if you match the cam right. You can get dart pro 1's on ebay complete for $950. What does your budget look like?
Old Mar 6, 2006 | 12:11 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
low budget, im in college
realisticly ill probably go with the double humps i have or a set of stock vortecs
all depends on what i get for a summer job
Old Mar 6, 2006 | 02:19 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
A price comparison.
$539.99(bare heads) + $325(spring/valve package) + $48(shipping) = $912.99
The GM Fastburn Vortec cylinder heads cost about $1220 before shipping. The Edelbrock E-Tec 200 cylinder heads cost about $1120 before shipping. You're saving some money, but I would get some opinions from people who have bought the product before shelling out the dough.
For mild combo you are planning, I would lean towards stock iron vortecs.
Old Mar 6, 2006 | 09:43 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
If you plan on using a small cam, under .480 lift, just get some used vortecs, check them out for cracks, and upgrade the springs. You can pick up some used ones for around $300. Springs under $80. Or you could get some bare vortecs from Racing Head Service for around $450 already machined,another $200 to assemble them. Then you need to decide whether your going to stick with self-aligning rockers or guideplates. You can pick up some good roller rockers off ebay for $150, but thats more power in themselves. So thats $800 spent. Plus the intake manifold and gaskets and nickel and dime ****, your looking at $1000. You can easily achieve 400 hp with unmodified vortecs. Theres a billion articles on this. Now its up to you if the 40-60 hp is worth $500?
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
