Intake bolt AWOL?
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Intake bolt AWOL?
So i went to my Grandma's house to visit my sleeping car (Michigan salt is crap) and i was looking at the engine when i noticed one of the bolts are missng from the intake manifold
its the bolt closet to the firewall on the drivers side... is immediate action necessary?
its the bolt closet to the firewall on the drivers side... is immediate action necessary? Thread Starter
ok so i take it my intake gaskets and stuff will be fine, they should be anyway but i think i may have to retap the bolt hole because i remember i torqued all the bolts down and it was all gravy then, but this particular bolt popped out...
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
popped out? like there are no threads there?
weird.. Buy a helicoil I guess.
ya its jus gone, and the threads are there at the bottom but they are too jacked up top to start another bolt, so i guess i gotta retap it, but is this a big deal?
Car: 1982 Trans-Am
nah, as long as there's no vacuum leak there, I wouldn't sweat it.
I'd strongly recommend popping the intake off and Heli-Coiling it....
Better now, than after your oil is contaminated by anti-freeze. Which is certain to happen sooner or later; more likely sooner than later.
well i jus did the intake last year and when i did i re tapped all holes to clear gunk out of em... and i noticed thos bolt holes went thru into the block, like you can thru em, so i think im in the clear with leaky coolant and that as of now ive got an unfiltered breather...
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
