no spark - coil or module?
Old Mar 5, 2006 | 03:16 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
had the car running yesterday and was gonna take it out last night and no spark... no warning, either, of course. i have the HEI with remote coil, 12V going to it and thru it to the module, but no spark. i have one of those spark tester things and put it on the coil wire itself and nothing. adjusted the gap to various gaps and nothing. (coil is fairly new, btw, about a year old with less than 500 miles on it) did a coil test today, one step says that it should read infinity, but not getting anything flashing on the meter like it normally does, even if reading an infinite value. so..., i'm thinking it is the coil and not the module. ?
Old Mar 11, 2006 | 10:45 AM
Car: '91 Z28
Axle/Gears: 323's
well maybe this will help... attempted to start it today (about a week later) and started right up. sounds like maybe something got a little hot? module has grease under it. any ideas?
Old Mar 11, 2006 | 11:53 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Could be the module cause my car did the same thing and it was the module. To know for sure pull the module and go to a parts store like O`reillys and have them test it for free. You`ll know in a couple minutes if the module is bad!!
Old Mar 12, 2006 | 06:30 AM
Car: '91 Z28
Axle/Gears: 323's
yea, that's what i was thinking... i had the module tested just recently, but i guess i'll carry my spare with me when i'm out of the area.
Old Mar 13, 2006 | 12:53 AM
iroc22's Avatar
There are quite a few things that could attribute to a no start condition. Id get the module tested again, it could be a problem. Try testing the pick up coil for resistance, Ive had it intermittently work before and then completely lose it one day.
MM2Robinson
Oct 1, 2017 09:16 AM
L98GTA87
Oct 19, 2015 10:43 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
