starting problem
Old Mar 10, 2006 | 02:12 PM
pat202's Avatar
Car: 92 firebird,2000 firebird
Engine: v6,V6
starting problem
i am hoping someone out there can help me i have a 1992 firebird V6 and every so often after driving i will get back in and the car wont start when i turn the key there is no engine turnover or its like trying to start it without a battery in it
but if i wait for 10 to 15 minutes try to start it, it starts have had a number of mechanic look at it none of them have an idea what it could be i have already changed the starter and battery no luck
any of you guys out there have an idea
thanks pat
Old Mar 10, 2006 | 11:38 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I had that problem not to long ago. My problem was the vats system. The wire inside of the ignition tumbler slowly broke loose over time and just the way it works threw me off with the turn it off, wait, try again and it works. I read somewhere that when you pull the key out it takes some time to reset itself, not sure if that was true or how long it would take exactly to reset. Anyway, try to insert the key, turn it forward a notch, just stop just before you try to turn it any further to start the engine. You should see the security light come on for a second, then turn off. This should mean that vats checks out. If you see anything else, this might be an area to troubleshoot.
Old Mar 10, 2006 | 11:47 PM
91TPIFirechickn's Avatar
Car: 91 Formula
Engine: L98 TPI
Axle/Gears: 3:42 posi
Sounds like GM starter heat soak.....
When it does this tap on the starter solenoid while someone starts the car if it starts its the starter.....
J
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
