L03----rough idle
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
L03----rough idle
90 formula with 305 tbi: idling really roughly....?! Changed (Plugs),(pick-up coil),(power brake booster),....the brake pedal is still harder than heck to depress! Could this mean engine woes like; valve spring or valve ----perhaps worse?! -brad
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Major vacuum leak. Check all the lines and gaskets.
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Originally posted by sennap1
Could it be that maybe the CAM went south...because of the brake pedal soo damn stiff?....thus creating compression/vacuum issues???????????
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Valvetrain issues are *possible*....but why are you jumping to that conclusion so early? Start with the cheap/simple, and work your way forward.
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Mechanic just told me: he tried a new (map sensor ) to no avail, sprayed (ether) for vacuum leaks-- there were none!, But when he pulled one of the injectors off it ran just fine! He showed me its getting (too much gas) through the injectors. What could be the cause? BTW: there are no codes on his scan tool. 305 TBI. 90' FORMULA......ALSO... the diaphram in the tbi unit checked out ok too....
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Have you checked the CTS and O2 sensor? A bad CTS and O2 can cause the ECM to dump all sorts of fuel at the motor if it is receiving a false lean condition. O2's are cheap so I would replace that just for the sake of preventative maintained. Your CTS can be checked with a thermometer, hot water, ice water and an Ohm meter. You can match up your recorded Ohm values and compare them to a chart. The chart is here on TGO but the search function is down. Perhaps you can find them on the net.
