lt4 hot cam,lt1 intake
Old Mar 11, 2006 | 10:50 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I am building a 87 l98 and am using the lt4 hot cam/and a 2500 stall. and an lt1 intake. staying with the 1.5 rr. The block is bored 40 over and I am using 10.1 flat tops.... my ?? is what kind of power should I have?? What kind of times should I run with a 3.42 gear?? can I use a turbo,nos,or a supercharger with this set up??
Old Mar 13, 2006 | 12:55 AM
iroc22's Avatar
The compression is technically too high for higher boost applications. You could run around 5 psi on a supercharger, you could run nos and I wouldnt really recommend a turbo unless you keep the boost low.
I would really recommend 1.6 ratio rockers since the cam lift is pretty low with 1.5 rockers.
Old Mar 13, 2006 | 08:07 PM
Car: 88gta
Engine: 357
what kinda power should I expect?
Old Mar 20, 2006 | 03:44 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I desktop dynoed your application for you. Came up with around 300hp at the flywheel. Ofcoarse this method isn't 100% accurate so you'll have to give or take a couple of ponies. Oh, and I think drivetrain loss for an auto is somewhere around 20%. Like was said before, you could probably run 5-6psi on pump gas supercharged or turbo. However, you could get the boost up even higher on a turbo app. with the use of some alcohol injection, but like any boosted app. it all comes down to how good you can tune and how big your brass is.
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
