Can i get some help real fast
Old Mar 12, 2006 | 06:48 PM
z28maro's Avatar
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
i wanted to know what my rocker arms should be torqued to. im in the garage right now on my lap top and id i appreciate a fast response
Old Mar 12, 2006 | 07:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
rocker arms? Like the rocker studs right? Depends on the rocker stud brand, maybe 35ftlbs if they're mr gasket non-collared, maybe 60ftlbs if they're ARP collared ones.
If you mean rocker arms, as in the actual rockers, you tighten the nut down, while spinning the pushrod, then after there's a bit of resistance, go another 1/2 turn or so, to put some preload on the pushrod. Or you can do it with the engine running.
Old Mar 12, 2006 | 07:07 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Basically, tighten the nut down until the lash is out of the pushrod then 1/2 a turn, tighten the locking nut on them, and while holding them together....another 1/8 of a turn. That's how I set mine and is recommend from Comp Cams.
Old Mar 12, 2006 | 07:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
remember to have the lifters on the base circle of the cam, or else you won't have them tightened properly.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
