pinning rocker studs
Old Mar 14, 2006 | 09:11 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
any recomendations on pin dia. and lenght from people who have done this ? and any sources for pins, no luck here at local hwd. stores.
thanks mike.
Old Mar 14, 2006 | 09:42 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
3/32" pin, 1" long. I bought 1000 from mcmaster carr, steel has the higher strength compared to stainless.
I could send you a handful if you can't find any otherwise.
Old Mar 14, 2006 | 10:39 AM
SPIKE's Avatar
Car: 86 CAMARO
sonix, thanks just found them in my mcmaster carr catalog. if you wouldnt mind parting with a few ill gladly pay + shipping. i would hate to buy a 1000 when i only need 20, 16 + 4 accidents. pm me if its ok.
thanks mike.
Old Mar 14, 2006 | 01:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, that's what I thought, but no one wanted to split gobs of them with me...
PM with your address, I can probably just throw a mitfull, 30 or something, into a padded letter envelope, it'd cost about $2. You can owe me one.
Old Mar 14, 2006 | 05:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I used a 3/32 titanium bit and also used 1in long 3/32 pins from Home Depot.
Old Mar 14, 2006 | 05:52 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I used a slightly smaller drill bit than the pin size so the pin fit quite snug. Don't forget the drilling oil, it helps once you hit studs.
Old Mar 14, 2006 | 08:41 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
the good ole boy treatment
That's why I like it around here.
Old Mar 19, 2006 | 01:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
not a lot of point posting this now, but I airmailed those out on tuesday I think, they should have arrived on friday, or maybe tommorow.
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
