building motor, words from the wise?
Old Mar 14, 2006 | 04:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm finally at the point of turning wrenches, and putting the engine together here.
350+.030 block
stock crank, turned .010 under
new ohio rods on new sealed power pistons.
So I just put in the crank, torqued down the arp main bolts (2 bolt mains), and checked end play, .005". a-o-k. I also plastigauged the mains, seemed good. put clevite bearing guard on the bearings, and a bit of oil too. sealer on the rear main cap.
Now i'm filing my rings to shoot for a .018-.020" end gap on the top ring (sealed power hyper H345 pistons). This is matching a ring to each bore.
slightly larger 2nd ring gap
not touching the oil ring.
should I worry about ring end clearance? or whatever the gap is called between the ring and the ring land above/below it? about .002" or so right?
and then piston bore clearance?
anything i'm missing so far? any tips or hints?
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
IroczFan
Oct 6, 2015 10:13 AM
gta90
Sep 15, 2015 04:00 PM
neekolzun
Aug 24, 2015 04:59 PM
