carb. vacuum
Old Mar 15, 2006 | 01:32 AM
z28maro's Avatar
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
carb. vacuum
im putting in a new carb. this carb has more vacuum ports than my old one. i just wanted to know if they were any side effects to not using some of them or hooking a vacuum to a different port. ie the input for the brake vacuum is odd shaped and it fits better on the one claimed to the pcv valve. Is mixing and matching lines alright or am i going to cause problems for myself
Old Mar 19, 2006 | 08:47 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
As long as you're using manifold vacuum, full time vacuum even at idle, should be fine for the PCV and brakes from separate fittings on the carb.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
